grill block mod = cheap power
#31
Originally Posted by CAMMIN03
have any of you guys tryed the grill block mod???? it's cheap and easy to make only $10 bucks....works well on my truck....it makes the truck more aerodynamic and will give you more mph in the 1/4 mile.....it helped me run 99mph in the 1/4 mile with a stock motor trans and rear no headers or a programmer and (no nitrous) 5000 pound race weight with me in the truck.........if your into cheap mods like me this is one you should try......
Right there...... quote you " it helped my run 99mph in the 1/4 mile with a stock motor, trans, rearend, no hears, or programmer, and no nitrous." thats what you said.....
duh......i never said that the grill blocks where my only mod ....i did say that my motor, trans and rear was stock (untouched never opened) ........i do have a homemade cold air intake, modded stock exhaust, spring clamps,removed swaybar, grill blocks, 2 inchlowering shackles, and tmr mod these are the mods i had to run 13.71 at 99mph........believe it or not i dont care......it's true.......i have too many witnesses that have seen my truck run
just because you dont know how to get your truck to run good numbers does not mean others cant get their truck to run good
my truck also runs mid 12s with a small shot of nitrous .....do you want to call b/s on that too?????
#32
the grill blocks did help me run 99mph along with the other cheap mods.....i never said that this was my only mod .....thats what you said
#34
Originally Posted by DanaliHD
ok, 2 questions: 1) what is a TMR mod?
2) what are spring clamps?
thanks
thanks
tmr mod is nothing but removing a wire.......torque managment request......it dropped my 1/4 mile times by 4 tenths ....it lets the trans shift faster and harder.....without the tmr mod the trans would shift slow and soft and cut power between shifts and that kills power and speed..........alot of guys have this mod on there trucks......i did it over a year ago and have had no problems
spring clamps are used for better traction.....they install on your leafsprings.....it's a old drag racers trick that stops the wheel hop and gives you better traction........theres a thread on the spring clamps over in the general forums......you can read more about it there........look for the thread paging h777....it's in there.....the spring clamps will also lower the back of your truck 1 to 1.5 inches
#35
heres a link for the spring clamps.......theres pictures and info there
https://ls1tech.com/forums/showthread.php?t=249201
#37
I assume the TMR thing is for Dodge trucks only?
#39
14 Second Truck Club
The vid will bring the BS flag down. That dodge will fly. Its a freak from hell. Wish my truck would run like his.
carid
07-24-2015 05:00 AM
04, block, blocker, blocking, blocksilverado, cheap, chevy, cut, grill, grillblock, grille, plexiglass, silverado, trucks
