Gutting cats/o2 sims questions
Old 05-06-2004, 02:57 PM
Originally Posted by jlwz71
More info on the y-pipe please. Never heard of it.
export pipe without cats for 99-02. Part #15045260
Old 05-06-2004, 03:21 PM
Will O2 sims make the SES light come on?
Old 05-06-2004, 04:17 PM
no they are their to turn them off. that or if you have edit you can delete the rear 02 sensors. or when you get a tune like Nelson.
Old 05-06-2004, 05:41 PM
Quikenuf's Avatar
how do i know if the CAT OVERTEMP PROTECTION is active? I had a local shop make a Y pipe without cats, but i do have simulators. do the sims take care of the cat overtemp or not? My truck has a nice new smell coming out the exaust, almost smells rich. Is the "COT" going to kill gas milage? How do I turn it off other than with EDIT? damn im full of questions!!
Old 05-06-2004, 07:09 PM
jlwz71's Avatar
Cool, thanks I will look into it.
Old 05-06-2004, 07:23 PM
HAZE's Avatar
they plug in between the o2 sensor and the pcm, it modifies the signal, essentially telling the pcm that everything is as it's supposed to be. these sensors are smog only and modding them won't affect your engines performance.
Old 06-15-2004, 08:57 PM
Need More N2O Mod
mwalls54's Avatar
ok i am still learning edit where do i turn off the back o2s? i just put on some really free flowing cats
Old 06-16-2004, 03:18 AM
HAZE's Avatar
edit>engine diagnostic>hardware diagnostics ,first window use arow to scroll to ho2s bank1 sensor 2 and bank2 sensor 2 [banks are left/right, sensor 2 is rear], click on what you want to change [highlights it] toggle "does it set ses " to off, next window toggle to type x off. generally more airflow will set a code for low voltage so start by turning those off. i only turn off what is needed to stop setting codes, these diagnostics are there to help let you know when something is wrong. but as far as the rear o2s are concerned i believe you can turn them completely off without worrying. when you get done with your changes don't forget to save the file, it will say "overwrite existing file ?" click yes. hope that helps. e
Old 06-16-2004, 03:57 AM
GREGGO's Avatar
Here is what I did. It sounded great when open, but I noticed absolutly no difference between cats or no cats when the cutouts were closed. When I took the cats off, I could see right through them anyway. Not worth it IMO.
Old 06-16-2004, 05:32 AM
Need More N2O Mod
mwalls54's Avatar
well when i was welding my flange on i dropped one of the pipes and cracked the junk in the cat so just finished them off. thanks for the help
6.0l RST
11-23-2015 11:30 AM
projectnightcrawler
09-30-2015 10:49 PM
chevstang421
09-10-2015 09:16 AM
carid
09-10-2015 09:07 AM
andrewlong
09-08-2015 10:25 PM
Quick Reply: Gutting cats/o2 sims questions
