Guys with cams
Originally Posted by Z284thgen
like 1 qt low from full or 1 qt low from the add line
Full. My oil pressure is fine, and it comes and goes. Usually if its cold it doesnt come on, but when I crank it again it will, and it always drinks 1 full quart to get to the full line. Hell at this rate, maybe I can switch to good oil, then just swap filters every now and then and never change the oil, just keep adding.
after my first cam swap mine was about 1qt every 1500-2000miles.... I changed the pcv valve and it fixed the problem... then I did my second cam swap and it started doing it again???? I havent tried the pcv valve again.. but what are the odds of it being the same???
Moderately Differentiated
FormerVendor
41K on the LQ9 and it doesnt use a drop, and I have about 3k miles on the Comp 224 so far. Although I did find some pretty thick build up on my drain plug magnet when I changed the oil after 4k miles this past weekend.
About 40qts every 3K
Quit bitchin your motor is fine. If you want to be **** then change out the valve guide seals and the pcv valve otherwise dont post anymore BS
I wasnt bitching, just currious. Also for everyone whose engine doesn't use any oil, are you actually measuring what you drain out, or just assuming because the light never comes on?
BTW Cody, I understand the LS1's by design do use a small amount of oil, but dont you think 40 qts every oil chang........er add is a little excessive?
Also, my light never came on till I changed the PCV. Before it was always just a little low when I filled up the empty quart jugs.
Tin Foil Hat Wearin' Fool
My oil light doesnt come on till 2 1/2 qts low
If it really bothers you change the pcv valve if that doesnt fix it then valve stem seals is what I would do.
