Guys with milled heads get in here
Old 10-11-2007, 10:47 AM
99/5.3w/hips's Avatar
Smile Guys with milled heads get in here
Those with milled heads on a 5.3 what length pushrods are you guys running and how much milling did you have done?
Old 10-11-2007, 12:05 PM
tdrumm's Avatar
.045 mill and 7.35" pushrods.
Old 10-11-2007, 03:15 PM
Silverad04's Avatar
I was told that with the 220/220 cam raising the comprestion ratio to 10 to 1 by milling .030 would help me see beter gains. I could still run on pump gas right? what pushrod should I use if I milled them .030?
Old 10-14-2007, 04:43 PM
southern_chevy's Avatar
anyone for sure how much you have to mill the 5.3l heads for a 10 to 1 ratio?
Old 10-14-2007, 04:52 PM
1TRUESS's Avatar
5.3L .030 & 228R with 7.350
Old 10-14-2007, 04:56 PM
v8
17,16,15,14,13,12,11 Drvr
well generally speaking, if you have a cam and are using 7.425 push rods, and then you mill the heads .25 then stock push rods could be used, if stock cam then minus the length that you mill the heads. hope this helps and if i'm wrong then someone will correct me I hope ahaaha.
Old 10-14-2007, 05:42 PM
kw05silverado's Avatar
^ do u honestly have a tornado?
Old 10-14-2007, 07:31 PM
v8
yes sir I do.
Old 10-14-2007, 07:32 PM
v8
I guess I should say my times 12.51@105.52 all motor baby 5.3 any other questions?
Old 10-14-2007, 07:40 PM
I used to have .030 milled with a 224/228 cam and 7.400 push rods. ran great
Quick Reply: Guys with milled heads get in here
