GY Eagle GT 2 275/45/20
Originally Posted by Tiburon
Any comments on the GY 295/40/20. I hear those have better traction.
Originally Posted by Yelo
same tread compound, same height, and only 10-20mm wider than the others GY's mentioned here....I can't see any better traction from them
I didn't say they were a bad tire...hell, I OWN them...I was saying that there probably isn't a difference in traction between the 275's, 285's, and 295's.....
Cornering IS good, traction off the line IS NOT.....as long as you can deal with having to roll easy off the line you will be VERY happy with the GY Eagle GTII's
If you are willing to drop the tire pressure a little too then the tire becomes MUCH grippier off the line (20-25psi is about perfect....not reccomended for anything heavier than a RCSB though)
Originally Posted by Chingon
What he said
These tires are kinda scary when it rains though
