Harland sharp 1.7 or yella terra 1.7 which one and why?
MASS seller approved
Good to know
That is correct back in 2009 we had a bad batch that has been resolved. We have no issues with our current products.
Jim YT
fyi...Main difference between the rockers is that the YTs have the largest shaft /torrington bearing setup, less nose weight than any other aftermarket alloy rocker system with an internal circlip on the roller tip.
Jim YT
I went with H&S 1.8 and like them so far. I upgraded heads and changed to rockers at same time. The change of both added alot to my little set up. I have the 5.3 CNC heads from SDParts and a HT1 cam 214/218 .559/.562 111 my lift with the 1.8 is around .595 so the head flow should be close. I also went with a pac1518 spring.
during the change I went with pacesetter long tubes and y pipe with no cats.
This is a 4x4 truck with 4.56 gears and 35inch tires. It moves along pretty good.
Jim YT
Jim YT
I just had a YT 1.7 break (pushrod side) on my LS6 head. Low miles and no abuse. Know where i can buy just 1 or 2?
gaps
10-15-2015 02:53 PM
