has anyone found a cost effective way to swap to an LS6 intake?
Originally Posted by Yelo
Forgive me for asking this....but HOW do you spend $700-800 dollars for this swap ??
I have a complete swap over kit that uses a ls2 90mm ssr intake. The advantage to this intake is that you don’t have to change water pumps and make custom brackets to make everything fit. The ssr intake will work I have had it on my truck and tested it out and it works great. The ssr intake will outflow a truck intake and get about the same flow as a ls6 intake but I had my intake ported so now it will out flow a ls6. hear is a list of the parts I have for sale as a complete kit.
05 SSR LS2 90mm intake has been professionally ported
06 Corvette 90mm throttle body
02 TAC
Speartech wiring harness adapter
These are the only parts you will need to make the swap.
I will sell everything for $820 shipped
02 TAC
Banned
1 Post
Do The Truck Injectors Fit For As Length I Have After Market Fuel Rails With Bigger Injectors And I Ls6 Intake I Just Did Want To Try The Swap Yet Did Not Know What Else I Needed
02 TAC
02 TAC
Originally Posted by Dark Halo
Is there anything special need when swaping to the ssr intake, will it work with the return fuel system like on my 02? Also what do you mean by 02 TAC? (forgive for being dumb but when I hear TAC I think Tachometer)
Throttle Body Acuator(sp?) Control
It lets your computer talk to the throttle body.
Anybody going to the 90mm TB needs one. It is located in the drivers side firewall under the support bracket
Mark
Originally Posted by 2004Denali
TAC
Mark
Mark
