Has anyone ran the MSD Coil Packs????
Old 03-09-2007 | 10:59 PM
03chevy5.3rcsb's Avatar
Default Has anyone ran the MSD Coil Packs????
I've looked and looked and have found no proof that these add anything but good looks. Has anyone ran these, and if so what were the gains? i'd like to see a before and after dyno if possible
Old 03-09-2007 | 11:10 PM
99LoweredSierra's Avatar
I saw pictures of someone on here that had them. Also 80mm throttle body help??
Old 03-09-2007 | 11:11 PM
Carlos's Avatar
would also like to know...
Old 03-10-2007 | 08:49 AM
Coban's Avatar
You will not gain anything from putting MSD coil packs on. You are better off getting a throttle body spacer. Even if they were 10 buck a piece I wouldnt buy them. If you are already getting a spark to the cylinder, a "bigger" or "hotter" or "longer" spark will do you no good.
Old 03-10-2007 | 08:54 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
In case you didn't know, this was sarcasm.
Spacer, coils, MAF, etc are a waste of money, most of us here have tried something that didn't do as advertised. Learn from others
Old 03-10-2007 | 09:43 AM
gUYS IT'S LIKE THIS....A COIL (NO MATTER WHO MAKES IT) IS NOT GOING TO GIVE YOU A GAIN IN HORSEPOWER. A SPACER WON'T, A BIGGER ALTERNATOR WON'T NO OF THAT TYPE OF **** WILL.
Old 03-10-2007 | 11:33 AM
BigCountryx's Avatar
Get one of these instead.
I'm aware of all that , but i'm thinking more along the lines of big injectors, fuel pump, rails. If you're dumping fuel, are these going to help (significantly) the combustion process. I know this is what tuning is for . And i'm not thinking horsepower gains, but maybe quicker response?
Oh and don't worry I'm not thinking of buying these, just curious.
Old 03-10-2007 | 11:37 AM
that tornado thing and alternator and spacer quotes? seriously guys come on I'm no retard
Old 03-10-2007 | 11:50 AM
CHEVRACER83's Avatar
hey bro theyre playin with you... loosen up... if we thought you were a retard you would know it.... relax.... if we dont **** with you we dont like you..... but no they wont necessarily help unless your cylinder pressure is so high you are misfiring and need higher output coils.... but on a motor thats running fine there will be no increase
Quick Reply: Has anyone ran the MSD Coil Packs????
