Have you ever broken your 10-bolt?
#21
Originally Posted by Scream
No, I'm just trying to see if this frail, eggshell 10-bolt is grenading on people. I just don't see the need for a 14-bolt.
#22
TOTM: January 2007
G80 broke first. a piece (pretty big) of metal then got stuck in the ring and pinion and fucked everything up. My pinion broke to pieces. i would recommend an aftermarket posi at the least to anyone who drives hard or just races occationally. Changing the posi will help a lot. A posi change is also a lot cheaper and easier than a gear and posi change. A posi is like 325 and about 150 to install it. What I'm doing is going to cost like a grand, so I would recommend a litle preventative maint. All the places I have called said the OEM gears are the strongest and quietest (and most expensive too!), so I guess the primary weak link is the posi.
#23
I think scream means more then breaking the stock g80, we all know thats weak
Eaton posi is where its at
#26
I have seen serveral in freinds trucks over tha last 20 years. Mostly axle and spiders (front and rear axles) and one ring and pinion. I have seen several bent housings on lifted trucks too. I have never has one gernade on me (tore the spiders out of a D60 once pulling it too hard with a few tons in the back!) because I have only owned one in a 4x4 burb I still have (but the gears are getting noisy now) because all my other trucks and 4x4's have have Dana or 14 bolt rear axles because I will not own a P/U with a 10 bolt in it in the rear because I buy a truck for a truck, not a car and I do no like even the change of failure if I can help it.
#28
Cuz I AM a BADMOFO
I think it would rob way too much power to justify running a 14 bolt rear with a 10.5" ring gear. I've seen plenty of 10 bolts hold up against power, but the best alternative for replacing the stock rear would either be a 9 inch ford, which could have any ends welded onto it, and doesn't need a c-clip eliminator as it doesn't use c-clips to hold the axles in....or a GM 12 bolt (which has a 8 and 3/4" ring gear) which can also handle substantial power without needing as much power to turn it as the 9". The thought of a 14 bolt rear with a 10.5" ring gear in a truck that makes 300-400 rear wheel is absurd. Get an auburn posi and at most a set of axles for the stock rear and it will hold up to just about any truck on this board...with the exception of a few.
#29
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Those are 8-lug, so you'd have to get them converted to 6 lug, or convert the fronts to 8 lug to match the rear. Are the 2500/3500 front brakes larger? Would it be a worthwhile swap?
#30
Wheel hop is what will break an axle shaft. Keep your tires firmly planted on the ground (or even free spinning without hop) and a strong aftermarket carrier / posi and you will be fine.
