Have you ever broken your 10-bolt?
#41
I originally blew a 2 inch diameter hole out the bottom of my differential casing. It was rebuilt with 4.10's and an eaton. I have since replaced the ring and pinion 3 or 4 times, I can't remember. And my most recent episode I chewed up the spider gears in the eaton. I do run on 33 inch tires, regardless I am currently hunting a 14-bolt or a Dana 60.
#42
OK this isnt reall off topic AND sorry if you think it is but I was wanting opinions on my rear end. I have a open diff and will be spraying 100 wet shot in 2nd gear and up with 16's. Should I really worry about my rear end at this time?
#43
#44
Originally Posted by zippy
unfortunatly with that big of a tire/wheel combo there isn't much you can do. probably a good one for a 9.5 14 bolt. should be easier to get 6 lug axles made for it.
If you can easily convert to 8 lug in the front...i.e. 2wd, then go with the huge *** pig 10.5" full floater. I don't think you could break that thing with 800-1000 hp with 44's. BTW the 10.5" FF's are alot easier to find than the 9.5" SF's. Converting a 10.5" to SF so you can use 6 lug axels is pointless IMO, seeing how you loose the biggest advantage a 10.5" has over the 9.5" and you'll break an axel WAY before you bust that 10.5" ring gear or differential. But if you can't find a 9.5"....it's pretty much the only option you have without converting to 8 lug or going with a custom built rear end.
#45
nothing is bulletproof. we've replaced 14 bolt parts at work in stock trucks and 4L80E's. sometimes parts fail, it happens. they just need to be replaced with the best you can get. this is always something to keep in mind when doing this kind of upgrade. going with more you than you should need isn't always the best idea.
#47
gmcyukon
10-03-2015 11:03 PM
Cha_Feel_
09-23-2015 09:06 PM
