having trouble starting my 2002 tahoe
Old 10-03-2004 | 08:24 PM
Default having trouble starting my 2002 tahoe
well im having trouble starting my 2002 tahoe, it turns over but never starts, i havent ever had a problem before so what could this be? maybe the fuel pump?
Old 10-03-2004 | 08:48 PM
Mn Avalanche's Avatar
Could be the fuel pump,or it could be the security system.Kinda like the security relearn yu have to do when yu swap pcm's.I would try the other key that yu got with it.Is security light flashing?Can yu hear the fuel pump prime yu turn the key to acc?
Old 10-03-2004 | 11:51 PM
not exactly sure whats going on with it, i pulled the vaccum hose of the fuel pressure regulater and some fuel drained out and when i put it back on the truck starts fine
Old 10-04-2004 | 05:23 AM
one03sierra's Avatar
Formerly one92rs
Talking
did you say fuel drained out of the vaccumn line when you pulled it off. if so the fuel pressure regulater is bad and needs to be replaced. the diaphram inside is leaking.
Old 10-04-2004 | 06:29 AM
SnakeOiler's Avatar
Yikes! When you replace that FPR, do an oil change as well.
treylittlefield
01-24-2016 07:38 PM
thunder550
10-08-2015 04:53 PM
1SlowHoe
08-05-2015 12:58 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: having trouble starting my 2002 tahoe
