Head bolts head studs and gaskets?????
I was talking with Richard at WCCH about some stage II heads for my truck.
I'm only looking for around a 10.1 compression so he did a 35mm shave on em for me so that i could use a stock size gasket.
He said that if i am goin to spray which i plan to run anywhere from a 75-150 shot from time to time. I should look into some ARP head bolts.
My question is do i need to do both the head bolts and the head studs together and will the stock gaskets be ok for what i want to do with the motor.
Which is basically the heads goin on and the juice with it. It might only see a 150 shot everyyyyy blue moon and more likely a 100shot for normal use.
GrooveCityZ71
08-31-2015 12:05 PM
slowlsx
08-10-2015 05:33 PM
signguy62
07-27-2015 03:42 PM
