head and cam suggestions......
Originally Posted by Quik
i know but it has been done before and we had no issues. is it tight? probably knowing thta a Trex is meant for stock motor with stock heads. a ls1 has flat tops and with ls6 heads still with in the stock specs that thunder goes by. its just on a larger cubed motor. i took the chance and it cleard and runs strong
Originally Posted by 912jonathon
if i was to put a set of 241's on my lq4, what would the comp. be? the reason i ask is because i have a set laying around
Originally Posted by litreddevil
you can shave the heads 50ths with no issue are 100 ths angle mill with no issue
GrooveCityZ71
08-31-2015 12:05 PM
