Head gasket question
Old 12-03-2008, 07:06 PM
Charlie@LsXperts's Avatar
Default Head gasket question
Can i use a 5.7 gasket 3.898 bore, on a 4.8 block i think the bore is .010 smaller 3.798
Old 12-03-2008, 07:20 PM
knuckles's Avatar
yes i did
Old 12-03-2008, 08:23 PM
quicksilverado's Avatar
I am suprised you don't know the answer to that working at Vegeance.
Old 12-03-2008, 09:10 PM
built408's Avatar
you work at vengeance, is this a trick question?
Old 12-03-2008, 09:43 PM
joshua022's Avatar
I did... u get some heads????
I went w/ a .040 gasket to up the CR just a lil.
Old 12-03-2008, 10:05 PM
Where's the Beef?
viciousknid's Avatar
More specifically. If the 5.7 is an LSX engine, then yes. If it's an LT1 No.
Old 12-03-2008, 10:53 PM
blue2003ls's Avatar
I have a set of the MLS gaskets for a 5.7 if you need them. I ended up getting the factory 4.8/5.3 MLS just in case. The part number is 12575329 for the factory GM part.
Old 12-03-2008, 11:02 PM
StrokerAce03's Avatar
Bore is 3.779 but yes the gaskets will work if they're standard LS1 size gaskets.
Old 12-03-2008, 11:40 PM
TurboGibbs's Avatar
If you get a set of gm gaskets for a 03 Z06 they are stamped 5.3HO/5.7.
Old 12-04-2008, 09:07 PM
blue2003ls's Avatar
Correct. They are cheaper too. here is the part number if you need it 12498544.
Quick Reply: Head gasket question
