Head gasket recomendation for 243's on 5.3
I have just purchased and milled a set of 243 heads .030 to go on my 2003 Silverado 5.3. I have dished pistons so that is the reason for milling. I am confused however on what head gasket to run. I was just gonna get the stock replacement fel-pro mls HG from oriellys or autozone, but I would like to go thinner around .040 for more compression. Can anyone recommend a good head gasket to run. I hear people recommending an LS1 or LS2 or LS6 gasket, but the cylinder bore size is different than the 5.3 so I am confused. I feel that you would lose compression from the head gasket bore being bigger? Or am I wrong. Thanks in advance!
Do u mean the LM7? His truck is the same as mine and I have the LM7. And I thought 799/243 heads didn't come stock on trucks til 07? Or am I misinformed? Idk it's 138am and I'm tired lol
TRIXXTERR (06-08-2021)
Custm2500's Rude Friend
They had 3 different 5.3L's for the silverado depending on the year.
LM7 standard 5.3L
L59 basically the same long block but flex fuel capable.
L33 high output 5.3L - 2005-2007 extended cab 4x4 only
when they switched to Gen 4 engines in the GMT 900 platforum is when you got 799/243 standard on the 5.3L but the RPO codes were different.
https://en.wikipedia.org/wiki/LS_bas...l-block_engine
No I mean an L33. It's an aluminum 5.3L. It uses 4.8 pistons and has 799/243 heads from the factory.
LM7 standard 5.3L
LM7 standard 5.3L
Yeah I found the cometic on summit, but my concern is that the thickness is good at .040 but the bore is 3.910 and my cylinder bore is 3.78 that's a 0.130 over bore. Wouldn't the over bore of 0.130 cancel out the compression I would gain from the thinner gasket. The stock replacement fel-pro gasket is 0.051 thick and 3.835 bore. That makes a lot smaller over bore at 0.055. I've always read that some overbore is good but anything past .060 on the gasket will cause you to loose noticeable compression.
Called Cometic and I had them make me a set. .040 compressed thickness and 3.810 bore, that's gonna make some nice compression. Wasn't cheap lol $180, but you gotta pay to play I guess. 🙌🏻
