Head Job
Head Job
on a BLOWN motor as well...funny stuff.
Alright question...having my stock 6.0 heads worked with larger valves and porting job, I have a decision to make on how much to mill these heads. Is there any benefit to doing this with my setup (in sig)? I mean the lower the compression the more boost you can throw at it, but .010 mill is not much, but worth what if any? Should you always mill something to clean the "line" maybe?
Mill or not to mill?
Lower compression does mean more boost, but not with a Radix. I am sure that your are close to pushing its limit. I don't think that with a Radix it is worth it. Get a good tune and run the hell out of it. That is just my .02.
milling is going to raise the compression now lower it.... you've lost me there. the stock 6.0L compression is more than fine for the low boost a radix puts out. even with the 2.75 pulley (the smallest i'm aware of) you aren't going to be able to overboost your truck at stock compression. i'd say leave the heads alone and go after other area's.
I had my 5.3 heads staged 3 milled .010. Then I got the 6.0. More Performance said my setup would work fine with those heads...so I kept them instead of putting on the stock 6.0's. Now I have kr like crazy with out injection and something over 93 octane. Plus I have a journal leaking...but nevertheless...just interested in where is the "line" for a compression ratio and the raidx....if anyone knew.
lxcoupe
08-26-2015 07:24 PM
