Header Collectors replacement??? Do V-Bands work?
I have a leaky collector that is driving me nuts. I don't care for the Bassani collectors so I am thinking about replacing them with a set of 2.5" v-bands. I have seen a few people do the same but haven't heard if they hold up to the test of time. Any input would be great.
Wrap a couple layers of aluminum foil over the joint. Then crank down a stepped band clamp over it. I learned this trick from a member here and it works! Much cheaper and easier than V bands too. Mind you, the joint I did it on wasn't a snug fit either so it does seal up nicely.
How much are they typically and where's a good place to buy them. They are pricey at Summit and the ebay finds look a little questionable.
Resident Retard
That may be a good trick for right now to keep it sealed for now. I just hate trying to get a wrench on the crappy flanges that come with the headers so I think replacement is inevitable.
This is where I got mine...
http://store.racing-solutions.org/vbands.html
I have also had good luck doubling up the 3-Bolt flanges to make them twice as thick. I just run a bead around the pipe inside and out, then weld another flange on top of that... But I love my V-bands!!
zblee
08-03-2015 03:45 AM
sauldgold
07-23-2015 02:15 PM
atxlt
07-20-2015 11:06 PM
