Header Flange Size.
Old 01-11-2010, 04:58 PM
SILVERADO11's Avatar
Default Header Flange Size.
I have Arizona Speed & Marine long tubes headers on my truck, i plan on building a new exhaust from the headers back, catless dual 3inch, i noticed after installing the headers that they are 2.5 inch collector's is this bad for my FI set up? I see lots of guys running 3 inch flanges with dual 3 inch piping all they way out back, im not sure if i should get different headers? or can i still some how do dual 3 inch piping at the header flang? mods are in my sig. someone help me!
Old 01-11-2010, 06:22 PM
03 BLACKOUTSSS's Avatar
I don't know too much about FI setups, but I would have to imagine that a free-er flowing exhaust is better. If thats the case, I would say a 3" merge collector is a good thing. Might want to consider saving on buying a whole new set of LTs, and buy a pair of 3" scavenging collectors and have them welded on in place of the collectors you have now. It will be about the same cost as a new set with the Tig welding and the collectors but they will be better than new.
Old 01-11-2010, 07:23 PM
Wish i never bought the az speed and marine LT headers, seems like i wasted some money. do you think that a real clean free flowing 2.5 inch dual catless exhaust with E-cut outs would flow decent for my set up ? or am i **** out of luck and have to bite the bullet and buy new Long Tubes. thanks for your input.
Old 01-11-2010, 11:30 PM
Any one else want to chime in?
Old 01-11-2010, 11:51 PM
terravast4's Avatar
My stainless works has a 2.5 collector so I don't think it is that huge of a deal. build you a solid dual 3", high flow cats with an x-pipe and some good straight throught mufflers and you should have sufficent flow. Some people are running 2.5 pipes with a FI set-up so go figure.
Old 01-12-2010, 08:48 AM
Thats what i wanted to hear! i was hoping i could just build a real solid 2.5 inch thanks for the input! any one else care to chime in???????
Old 01-12-2010, 03:07 PM
Coban's Avatar
I don't think dual 3" is necessary either. Do use the 3" cats though.
Old 01-12-2010, 03:14 PM
thanks for the info
kha4079
10-29-2018 04:38 PM
Superman09
09-25-2015 05:55 AM
5.3lSilverado
09-20-2015 06:48 PM
Cowboy Tom
11
09-16-2015 09:35 AM
Quick Reply: Header Flange Size.
