header install
Old 01-30-2009, 06:41 PM
JakeBrakeIH's Avatar
Originally Posted by Go5.3tt06
Hey I can see my obx and ypipe with fake cats show that 4 bungs holes. I want to know is my stock o2 senor wires able have room to plug in? It seem long pipe that where 02 sensor blungs are. Let me know.
yes they are long enough, mine has 6 bungs i think for a wideband or whatever u desire...
Old 01-30-2009, 06:55 PM
BigCountryx's Avatar
they should have 6 bungs on the OBX. Your o2's will fit fine, but the rears need to be turned off and you will need 2 plugs
Old 01-30-2009, 11:06 PM
YenkoChevelle69's Avatar
I've heard you can plug them with 2 spark plugs.
Old 01-31-2009, 04:42 AM
CashDudeHomie's Avatar
Make sure you plug the 2 extra bung holes.
Old 01-31-2009, 07:32 AM
PT's Slowest Truck
budhayes3's Avatar
I'd put the rear O2 sensors in and plug em in so it looks all legal-like
Old 01-31-2009, 08:22 AM
GMCtrk's Avatar
to plug the rear holes you need to go to autozone and buy 2 toyota oil drain plugs.
Old 01-31-2009, 03:21 PM
PT's Slowest Truck
budhayes3's Avatar
Toyota has 2 different size drain plugs, make sure you get the bigger of the two if you go that route.
Old 02-01-2009, 07:52 PM
Go5.3tt06's Avatar
Hey everybody.The installed is pretty cool but sometimes painass from the fitting issues! So far all OBX are up bolts on. And the y pipe with fake cats are on. So last one the lightning muffler with passenger side have problem the fitting to connect the y pipe. It not straight right. So all I need to take to SHOP this week let them do cut few inch off and re-welding. So I able have all muffler back on correct with level. But the sounds pretty good. I run with Hooker Amechamber. But I could tell from stock cats compare with fake cats the smell totally different! The fake cats smell like racing. I suppose to change thing the smell? I just wonder the fake cats will kill mpg?? That what I am consider for. Many thanks. P.S. soon post all pictures on this thread.
Old 02-01-2009, 08:32 PM
GMCtrk's Avatar
You just have to deal with the smell. After 6 or so months I was fed up with it and went with cats. No noticeable loss in power and no more fumes.
Old 02-01-2009, 08:47 PM
hirdlej's Avatar
The smell will go away when you get your catback hooked up. It'll direct the exhaust out from under the truck. Also once you get it retuned you'll feel the performance difference along with see better mileage.
Quick Reply: header install
