header install
Old 02-15-2009, 09:26 AM
  #51
Go5.3tt06's Avatar
Hey. Today bad news I install the protect boot for spark wire cover. SOmehow the OEM spark wire have steel boot with springs. So the taylor boot sleeve not fit. SO I have to take steel boot with springs off. It work and plug in. I drive and its shake. DO I need put all steel boot with springs back together?
Old 02-15-2009, 10:21 AM
  #52
Go5.3tt06's Avatar
Guess what I found one spark wire is cut. I guess ahead buy whole new MSD wires. DO I need put oem steel boot on it?
Old 02-15-2009, 10:22 AM
  #53
JakeBrakeIH's Avatar
I dont have mine on my plugs...took em off when I didnt my headers in March...no problems here
Old 02-15-2009, 10:40 AM
  #54
Go5.3tt06's Avatar
then why have spark steel boot with springs in first place that where factory came. NOW I found spark wire is cut hole thats why its shake. Im going pick up msd wire from summit store only 30 minutes away from here
Old 02-15-2009, 10:54 AM
  #55
i have no idea, im sure its some reason but i always hated them...major PITA when changing plug wires...
Old 02-15-2009, 12:55 PM
  #56
PT's Slowest Truck
budhayes3's Avatar
They're heat shields to help protect the stock wires. If you're going with MSD's you won't need to put the heat shields on...they won't fit and the MSD's are made of a more heat resistant material anyway.
Old 02-15-2009, 09:42 PM
  #57
Go5.3tt06's Avatar
DONE replace new spark wires set (MSD 8.5mm) and taylor red boots. Everything great.
Old 02-15-2009, 09:53 PM
  #58
GMCtrk's Avatar
your truck peels out more with the stock exhaust than the headers?
Old 02-15-2009, 10:51 PM
  #59
Go5.3tt06's Avatar
What do you mean? You mean the muffler coat paint peel off? There is no peels at all.
Old 02-15-2009, 10:56 PM
  #60
Baltimore Whore
Mangled03gmc's Avatar
Meaning it spins the tires more with the stock exhaust on it, then with the headers.
Quick Reply: header install
