Header leak
Header leak
Hello all, I have a 6.0 Escalade with long tube headers and recently sprung an annoying exhaust leak that I have determined to be coming from the header at the the head. I have had no real issues since i have owned the truck for about 4 years. Is this normal for the gasket to fail or are my headers warped? What do you guys recommend for me to fix this? Is there any special gasket recommended for headers that I should buy?
Thanks in advance!!
Thanks in advance!!
Baltimore Whore
What headers you have ? Also did you reuse you MLS oem gaskets or the ones that is supplied with the headers ? Have you checked to make sure a bolt didn't break ?
11 Second Club
Probably just a gasket failure. More likely the header flange would warped before the head surface. That said, new gaskets and cleaning the surfaces will probably fix the problem. The best sealing gaskets are the GM MLS gaskets like you can buy from Texas Speed or the dealership if you don't mind paying extra. Torque the bolts to 18 ft/lbs working progressively from the middle out to the ends. I usually torque first to 15 ft/lbs and then do a final sequence of 18 ft/lbs. Be careful not to get the bolts cross threaded when you start them. The aluminum threads in the heads are real easy to damage.
Cool thanks again! I'm attempting this right now. Took the old one off and I noticed the performance shop that installed the headers originally put silicone on both sides of the gasket. I have no idea how I am going to get a torque wrench to fit anywhere near these bolts.
