Header Tick
Header Tick
Hi all,
I installed a set of the ebay long tube headers this weekend after talking to rel3rd (Thanks again!), and have developed an annoying ticking noise.
On the very first start it was very noticible even at idle, and once warmed up it went away, but on the drive home any time I accelerated above 2000rpm it returned.
I'm going to try and retighten all bolts, but I'm just wondering if ticking is normal on these engines with headers due to the thinner material on headers, or if they should be silent meaning I likely have a leak.
Just wondering what everyones experiences have been before I go crazy torquing all bolts.
Headers clear the steering knuckle, and do rest on passenger side frame but I get a different noise from that at certain RPM's but it is very easy to pinpoint that as the cause of the other noise I hear.
I just went out and rechecked the actual bolts where the headers meet the head and most were so tight that I didnt go any further, while only a couple were slightly loose but I only got at best a quarter ratchet turn on them.
I'll check the collector bolts when I get it back on the lift, as I did have a bad time with those to begin with but I thought I'd gotten them. Its just hard to figure out exactly where the noise is coming from.
I just took the truck for another spin and again on startup is was noticibly worse, but even at temperature I got the ticking above 1500-2000RPM. Oddly enough when I revved it in neutral it wasnt as noticeable.
Edit: Also, I put brand new OEM gaskets on, and got new bolts but they are the same as the stockers were. I also did new plugs and wires while in there if that makes any difference.
Ok thanks for the help. I'm for sure checking those collectors when I get a minute, as I really doubt its the actual header into the engine because the fit there looked pretty good, but if I have to I'll take a real close look. This is my first header install so I wasnt sure if it was possibly normal, but I didnt think it could be haha.
Are there any bad effects of my driving with a leak for a few days before I get it up on the lift, other than annoying me?
