Header wrap
You can see as little as a few months to as long as a few years depending on the tubing grade and thickness. As long as you run decent warmup cycles you can extend the life of the tubing significantly- the problem with wrapping is you will absorb moisture and this moisture does a number on the metal if you don't evaporate it with heat. Just warming it up and not getting the moisture out (like short trips to the store) will advance the corrosive process.
The machine shop I use installed a dyno a few years ago. He told me that one of the biggest differences he noticed inside the dyno room was when they started using ceramic coated headers during sessions. Said the temperature in the room was dramatically lower than it was before when they used painted headers.
