Heads, New Cam, and Intake install on my 4.8
#161
Yep it is a 4.8 unfortunately
I will say this, the new heads made my verter alot looser, which is good and bad... I liked the way my verter was before not tooo loose not tooo tight, now it is a tad tooo loose.. It poped the PO757 code yesterday, which sucks, i need to tune it out, but i have been lazy... My 60fts better be in the 1.8 range now
#167
#168
I will tell you that my FTI rebel TQXL increased my exhaust volume and low end tone by about 30% LoL. I still haven't driven the truck after the cam swap. It's still hibernating in the garage for the salt and sand to get off the roads. My truck never droned a bit with any of my previous setups, my new FTI cam totally changed everything. The truck has a mind numbing low end growl. It sounds like a big block marine engine if you've ever heard one run. Where they run the exhaust under the water. No cackle, just loud and low sound frequency. I like it You'll definatly draw attention wherever you go. There's no mistaken that it's something you don't want to "F" with.
#169
For example, my current cam dropped the lower areas of my VE table by about 60%(400rpm)-40%(800rpm)-20%(1200rpm).
Then when i added the heads, it increased the same rows by about 10-20%, strang huh?
Now i am curious to see what the new cam does....
Also if i would have added all three of those parts at once, i bet i would still be trying to get it to idle ...
Me too
#170
Wearin' da big hat
Yep, the MAIN reason i decided to do it this way is to see how the parts affected my tune.
Me too
Interesting in a good and bad way... I don't need my truck to be any louder than it is right now...
Me too
