HEEEEEEEELLLLLPP!!!! Please
Old 10-04-2004 | 09:17 AM
01Blackerado's Avatar
Default HEEEEEEEELLLLLPP!!!! Please
Ok i just got to put on my shanner S2, the problem s that it came from a Camero and it seems the throttle is staying open instead of closing all the way and being able to idle!!! The problem also looks like the actual wing on the throttlw body that routes the wire is bigger then my stock one thus not allowing it to stay closed when theres no gas pedal being applyed!! Can anyone help me out what do i do????
Old 10-04-2004 | 09:20 AM
greentahoe's Avatar
Originally Posted by 01Blackerado
Ok i just got to put on my shanner S2, the problem s that it came from a Camero and it seems the throttle is staying open instead of closing all the way and being able to idle!!! The problem also looks like the actual wing that routes the wire is bigger then my stock one thus not alowwing it to stay closed when theres no gas pedal being applyed!! Can anyone help me out what do i do????
I thought the Throttle bodies from F bobys and trucks werent interchangable?? Did you specify that you had a truck??
Old 10-04-2004 | 09:21 AM
Yeah i thought i did and he said it would work!!!
Old 10-04-2004 | 09:25 AM
greentahoe's Avatar
Im sure someone else who has a 100% definate answer will chime in, but Im pretty sure that they are not interchangable. 02Denali may have a more certain answer since he has a redone throttle body on his truck
Old 10-04-2004 | 10:40 AM
If your throttle is not closing all the way you could try moving the first bracket the cables run into from the throttle body on top of the intake. Move this bracket forward.
I had to do this twice, 1st when I put bbk throttle body on and 2nd when I put a motorvator spacer on. Move forward toward the radiator then the blade will close. Probably have moved mine forward now about 2 to 3 inches.
Hope this works.
Old 10-04-2004 | 11:13 AM
Ok thanks ill try that real quick
Old 10-04-2004 | 12:58 PM
Did it work?
Old 10-04-2004 | 05:35 PM
one03sierra's Avatar
Formerly one92rs
Talking
i have a shanerported tb. and i think the one i got was for a camaro also. all i had to do was bend the tube back some that went to the valve cover hose. you need to look and see if the cable holder is bigger. if it is then it will not work. shaner is a nice guy. give him a call and see what he says.
Old 10-05-2004 | 07:24 AM
Hey it worked i just moved the bracket foward like you said and waaallaa nice job dude. Thanks
