Help!!!!!!!
Old 08-15-2004, 09:30 AM
superchargedchevy02's Avatar
Default Help!!!!!!!
Is any one else having any kind of detonation with their SC? As I stated in my other post Kenne Bell has retuned the PCM and it didn't help much their solution was to run the NoS octaine boost which evaporated in about 15 minutes in this Texas heat. So please Any help is appreciated. Oh yeah I don't have a vacuum leak that was the first thing I checked.
Old 08-15-2004, 11:01 AM
Black Blown 02's Avatar
You need to get a scanner hooked up to that thing to see what the real problem is. It could be alot of things causing your detonation.
Old 08-15-2004, 11:24 AM
We did hook up a scanner what should we look for?
Old 08-15-2004, 11:29 AM
One thing just hit me would to much backpressure cause this? I did change the plugs I went with the recomended 1 heat range cooler that KB recmends Denso
Old 08-15-2004, 11:30 AM
Log timing all through the rpm range, log knock retard, log your 02 voltages, log intake air temps. It'd be really nice to get it on a wideband too.
Old 08-15-2004, 11:32 AM
I think it could. Too much leftover hot exhaust gas in the combustion chamber could cause detonation. What's your exhaust setup?
Old 08-15-2004, 11:33 AM
Gibson Super Truck cat back, still running stock cats
Old 08-15-2004, 11:38 AM
Maybe you've covered this somewhere, but how much boost are you running? Does the Kenne Bell have an intercooler. In hot weather, you might have problems running more than 6psi with a twin screw non intercooled.
Old 08-15-2004, 11:44 AM
7psi no intercooler
Old 08-15-2004, 12:02 PM
7psi no intercooler
Parish had a Whipple on his old truck, and I think he had detonation above 6psi in the summer. I'm not sure on that though. hopefully he'll chime in on this one.
Iat's on a non intercooled setup are HUGE, especially in summer. That may be your problem. You may want to look into an alky injection setup.
