help
dont care about gas how much faster will it be and how big of a cam i still wanna use it as my daily driver i just really wanna smoke hemis and lighting...but who doesnt... stupid question but what does flash to 4000 mean? so what gears should i get i wanna do 390s will those be ok??
17,16,15,14,13,12,11 Drvr
if its supposed to be for a camaro that weights in at 3700 and your truck weights in at 4500 then the 3600 stall becomes a 4000 stall. your truck wont move untill 3k rpms ahahahaa. good luck on the converter.
well its going to be very fast out of the hole if you get traction, DD you will lose about 3-4 mpg, it will get very hot in traffic, you will def. need a large tranny cooler to help keep temps down on the transmission, 01thunder has a 3500 stall converter in his and likes it, try it out and if you like it keep it, if not sell it to a camaro guy. Good luck on your quest.
Destroyer of Transmissions
The gears, I'm not sure about. 3.90 with that much stall in your TC...I dont think you'll ever get the tires to hook. You planning to but ET streets or something?
Banned
1 Post
it will not fit any way the bell houseing is shorter on the f body than on the trucks
you will need to send it to them and get thicker pads where the verter bolts go
11 Second Truck Club
humm, kind of strange since i've put 6k mi on it with no problems.
now i do understand that a vette converter will not work with truck or f body applications.
Banned
1 Post
Originally Posted by bluecajun5.3
so your saying that my tci converter pn. 242937 will not work.
that is a chance you are taking the bell houseing is a 1/2 shorter on a f body so yes it may work but it is not in the front pump like it should be now yes you can put washers but be careful that you don't put to many.
unless you changed your bell houseing
i wish i could get some pic up to show you i don't have any f body trans right now i will have 2 of them this week and i will try and get some pic up to show you.
