help on 6.0L cam
help on 6.0L cam
i have the 6.0L and im trying to find a good cam for it and the website would help out too. i want a noticeable lope with good horsepower but also something that doesnt die at ever stop light( a few here and there is fine : ) ). i wanted to go with comp cam and im trying to find the whole kit. any help?
Formerly one92rs
a 224 --224-224-581-581-112+4 was what i ended up with. that thing would not keep an idle for ****. if it was hot or cold. it would die everyonce in a while. the power band was up from 2500 to 2800 and up. i guess it depends. do you want to put in a stall later. then do a 224. if not then i say do the 216-220
FormerVendor
Originally Posted by stssilverado
Nelson perf has specs for a cam that was tested at nickens racing to pull 441 hp on the dyno in the 6.0. might contact Allen.
Banned
1 Post
I Have The 216/220 And With The Tune For The 5.3 First Time Out 2 R 3 Weeks Ago Ran 12.46 At 108.
I Would Either Go With 216/220 R 212/218 With 558 Lift JMO
