HELP!!! Bank 1 lean
Old 07-13-2006 | 11:58 AM
CurtD's Avatar
10 Second Truck Club
Swap the front o2 s from one side to the other and see if your problem switches sides. If so you need a new sensor.
JRsilverado's Avatar
Originally Posted by BenKey
Ever had it off before?
I was thinking about the air intake (K&N). The actual engine intake has never come off.
Old 07-13-2006 | 12:04 PM
Would a bad front O2 sensor effect the rear one? I'll give it a try.
Old 07-13-2006 | 12:33 PM
Doobie's Avatar
Bank one should be the drivers side. Rear o2 monitors cat performance and front o2 monitors engine performance.
Sounds like intake/exhaust leak assuming o2 is functioning properly.
Old 07-13-2006 | 12:37 PM
Okay, I see now. If the front one is messed up and telling the engine to do something wrong, it will effect the rear.
Thanks.
Old 07-13-2006 | 01:00 PM
You damn Navy guys......
Old 07-13-2006 | 01:08 PM
Yeah, I'm not even a Nuke and I'm Nukin' it!
What rate are you? You must be an engineer. CTT here.
Old 07-13-2006 | 01:28 PM
01Blackerado's Avatar
Another way to check the intake manifold, is to turn the truck on...grab a water bottle, and spray towards the intake manifold (not the K&N) . Make sure to spray very very little at a time incase you have a leak. If you have one, engine will stumble a little once you hit it with the water. DO NOT OVER SPRAY...keep it short and sparatic.
Old 07-13-2006 | 02:00 PM
I'll kick you in the shins for that! I'm a FC
Quick Reply: HELP!!! Bank 1 lean
