help cam
help cam
Hey I spoke to chris from hunterperformance.com I already explain everything for my truck what I need also I still do tow sometimes. He offer me to run cam which is custom hps comp cam xer lobes duration @ .50 int 232-ex 234 lift int 595 ex 598 on a 114 lsa. And comp cam dual valve springs set 921's I dont want run dual spring or I have to?? That is to much for those? Also they offer me get circle d 2700 stall? Why cant stick with 3000 stall? Do I have to get comp cams ls2 adjustable timing? My truck is 2006 Silverado 5.3 Im confused. When some people offer tr220 or 212-218. Now this different info. It seem not right to me. I really want to know and safe my neck than sorry to buy wrong kit. I want find right parts before I order it! Can you guys help me out this detail?
Baltimore Whore
You are not going to be able to run a stall that large, cam that large and expect it to be good to tow with. You either want a tow truck or a performance truck. You can get a 2700 verter that will allow you to tow. That cam sounds a tad on the big side for what you want to do all around with your truck. Stick with the tr220, a 2700 converter. It will not be a super tow truck but will get you by to do what you need it to do. It will not be the best turbo cam, the with a 112lsa. You need to make up you mind 100% and go with it, stop talking your self out of 1 thing or the other.. Get what is the most pratical, best all around suited for you.
