help with cam install
Yes, they are expensive.
You are raising your compression by using those .040 Cometics. If they have the same bore as the stock gasket, then your compression ratio has gone from 9.4:1 to roughly 9.8:1. Not exactly the right move for forced induction.
You should really get some stock thickness GM gaskets for this motor. BenKey found a set of stock replacements at a normal parts store. They were FelPro brand, graphite .060 thickness.
You could sell the Cometics (or trade me for my stock GM MLS 6L gaskets and cash).
Originally Posted by parish8
comp cams, 234/232 598/595
the card also says HR115+1 and it says "specs are for a cam instaled @ 114 intake center line", soo what do all those last numbers mean?
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
Should run like an animal in a stock 6.0... be sure to let us know.
damn, tex is right, hmm, now i got a decision to make, i dont want the felpro's, some stock mls would be cool if anyone has them in stock.
i might just run it with the 9.8 compresion, qmp is running 10.1 compresion and geting crazy numbers, i am only looking to run this thing for 6 months or so, then the 409 goes in. hmmmmm
I thought that stock head gaskets compressed to .059",I think with the cam you are running the compression ratio won't be nearly as important as it would be with a stock cam the increased lift and duration will lower your actual working compression ratio,the calculated compression shouldn't matter.
ok, i just checked the compresed thickness of those all ready instaled cometics and it is exactly .040. the only assembeled motor i have here is the 4.8 and it has the mls gaskets, the compresed thickness is .046. not sure if the 6.0 gaskets are thicker or what but not and there is really only a .006 diference then i wont mess with it, still looking for more info.
gota wonder if "ignorance is bliss"
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by BigTex
first time for everything.
Take a look at some threads in the internal section about having to fly cut pistons with big cams. You are nearing that territory with the thinner gaskets.
I have a set of MLS gaskets.![Angel](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_angel.gif)
i think i will run these gaskets. i just measured the 4.8 head gasket thickness and it is .046 and it is a mls gasket. the cometics are exactly .040 like the package says. even if it is 9.8-1 compresion that means it should run damn hard right now, have to limit myslef to 6-7psi when the turbo shows unless i have some good gas.
