Help Choosing Pushrods
Old 01-20-2011 | 09:27 PM
ByuTrukr's Avatar
formerly ByuTrukFreak
Default Help Choosing Pushrods
I milled the heads .050, i'm using the LS7 lifters with a .050 Cometics head gasket. I'm gonna get the 5/16 .080 walled pushrods. I'm not sure which ones to get, here's the choices.
1) Crane Pro Series Aircraft-Quality 4130 chromemoly
2) Crower 4130 Seamless chromemoly
3) Comp Cams Magnum High carbon C1020 chromemoly
4) Trick Flow Specialties 4130 chromemoly steel
5) Comp Cams Hi Tech High quality premium steel alloy chromemoly
Old 01-21-2011 | 08:54 AM
ByuTrukr's Avatar
What's up 34 people read this and didn't have an opinion? I'm sure somebody has an opinion.
Old 01-21-2011 | 11:31 AM
Gadgetized's Avatar
I have comp in my truck. I honestly don't think it makes a difference as long as you are running a good aftermarket push rod.
Old 01-21-2011 | 01:35 PM
Country Boy's Avatar
Senior Member
They are all the same. Theres only maybe 1 or 2 pushrod manufacturers. Everyone else just puts their name on them.
Old 01-21-2011 | 02:27 PM
ByuTrukr's Avatar
Thanks for the opinions, these are the ones i'm leaning towards:
Probably leaning towards the Comp Magnums more than the others, but not sure about the high carbon C1020
Old 01-21-2011 | 02:46 PM
Coban's Avatar
Just get the right length.
I believe that 4130 is a stonger steel when heat treated. Granted pushrods act in compression so tensile strengths are pretty irrelevant. Elastic Modulus would be more relevant to buckling.
Old 01-21-2011 | 04:28 PM
ByuTrukr's Avatar
Yeah we did the measuring came to 7.3"with .067" preload, thanx.
JordanH
11-06-2015 08:42 PM
jtphelps289
09-29-2015 01:00 PM
sTNT971
09-26-2015 05:22 PM
OHsixLS3
09-25-2015 05:38 PM
97_ek
09-23-2015 10:16 PM
