HELP! F150 LS Swap 4 Oxygen Sensor problem
Old 03-29-2021, 11:08 AM
Registered User
Rafal Styczen's Avatar
Originally Posted by terravast4
How are you going to pass California smog with a motor that was never offered for that year or make?
California engine change rules are well defined. If you meet the Gross Weight category and Truck type engine it is fine. I have checked the engine with the referee. It is ok.
The biggest problem was tank conversion. None of the new plastic tank were fitting my frame. I had to use my old F150 steel tank and weld ports for the sender unit from Tahoe as well as vents for EVAP.
lxcoupe
03-09-2020 07:44 PM
Kilgorq
04-23-2017 01:36 AM
EmmerichLSx
02-25-2016 12:57 PM
Twentyhurtz
05-26-2013 03:06 PM
Ezskanken
02-28-2012 01:47 PM
Quick Reply: HELP! F150 LS Swap 4 Oxygen Sensor problem
