HELP! HELP! HELP!! Cam Install Problems
Old 10-29-2005, 11:58 AM
10 Second Truck Club
67SS509's Avatar
Originally Posted by O3GMC
You would think Thunder would know this and not cause such aggrivation selling these tools to 02+ owners.
Sorry to hear about it man, hopefully the 3/16 will work, if not, I used 16 pen magnets with no problem, just test them all out first.
That's not the problem. I have done enough now and looked at enough bare blocks to see what is going on. The passage way that the rod is inserted thru is drilled halfway thru the block from the front and then the rest is from the rear. They don't always meet in the middle dead on. Probably about 2-3 blocks out of 10 will not work with the JPR tool or rod method. I have seen some blocks with a 1/4" mis-match. This is when you have to use the magnet method or chance method.
Old 10-29-2005, 12:52 PM
Fogle07's Avatar
on mine i just bought some rod and ground a flat spot on them. i kept taking a little off at a time till it would go all the way in. i was having the same problems you were. just take a little material off at a time till they slide in. it will work
Old 10-29-2005, 01:52 PM
11 Second Club
GMCHammer's Avatar
SC, You get that cam in there yet? Don't make me come down there and show you how to put that thing in. If I do I might have to bring a motor back with me.
Old 10-29-2005, 09:33 PM
98TAauto's Avatar
we usually just spin the crank and it you dont hear the hitting them all is usually well and just hurry up and get that cam in. My 04 didnt hit anything when we turned the crank over a few times. But we did a 00 and all you heard was ting, ting, ting were a lifter kept dropping. We just used 5/16th dowels in it and those worked perfect. I wasnt about to spend cash on that JPR tool when they dont work half the time
Old 10-29-2005, 11:19 PM
Okie5.3's Avatar
i had the same issue when installing mine. using a 5/16 wooden dowel it slid right in on one side with no problems. the other side would get hung up a little over half way back. not like a dead stop, but rather it would start tightening up until it stopped. i had bought a 1/4 dowel just in case so i tried it and it slid in just fine.
Old 10-30-2005, 04:52 PM
SCIV's Avatar
Well after much hoopla about nothing, I spun it like crazy & just pulled it. No problems at all. I want to thank everyone for all their help; especially Jethro3 for helping me out & doing all the hard work.
The idle is quite choppy, and has a great sound to it. 500 rpms is a little low it seems for this to try & idle. I am hoping to go to Allen's Friday for a live tune & dyno run, then to San Antonio Raceway on Friday night for paper proof!!
Old 10-30-2005, 08:23 PM
what a rush!
moregrip's Avatar
congrats! what are your cam specs?
Old 10-31-2005, 11:55 AM
SCIV's Avatar
Thanks moregrip.
TR 224/224; .563/.563; 112 LSA
TR Pushrods
Comp 918's & TI retainers
Just got the confirmation from Allen for a Friday afternoon street & dyno tune. It needs it!!! I can't wait
New rims & tires should be ready tomorrow!! (18" X 9" Boze wheels with 285/60 BFG KDW2's) Then Friday night to the track!!
Old 10-31-2005, 06:05 PM
11 Second Club
GMCHammer's Avatar
SC you get a chance post up some sound clips or video's. I wanna hear what that beast sounds like. Keep us posted.
all_individual
10-10-2015 10:09 PM
low2001gmc
07-23-2015 05:10 PM
lxcoupe
07-21-2015 02:12 AM
ssierra08
07-15-2015 06:40 AM
all_individual
07-13-2015 11:01 AM
Quick Reply: HELP! HELP! HELP!! Cam Install Problems
