Help, I locked up my engine today!!
No trouble codes, other than the usual O2 sensor and speed sensor codes that have always been there.
I haven't felt any slippage, but it could be. I don't have much experience with transmission problems.
My ETs suck because Temple Dragway is absolutely horrible for anything but drag slicks. They had a Viper and Z06 running high 12's/low 13's last weekend.
Thanks again for all of the replies. If I don't find anything broken in the engine, how do I check the converter?
put it in nutral, and take off the drive shaft from the trans . . . it "should" turn over by hand. Other than that I have no other ideas on how to "check" it.
pull the pugs and put a wrench on the crank . . . see if it spins over.
Are you sure that you didn't break a belt ?
So... the first Comp 918 valve spring on the #7 cylinder broke along the topmost coil, dropping the valve into the cylinder. The spark plug wasn't damaged, but I didn't pull the head off yet to see what kind of mess there is.
I don't remember the spring batch#, but I remember the julian date showed them manufactured in late May 2006. They had a blue or green stripe. It was hard to tell which color it originally was, it is kind of a shade in between the two.
Anyone ever dropped a valve and NOT have catastrophic damage?
