HELP! Lost transgo instruction sheet!
well.. title says it all,, i am going to install my transgo kit tomorrow, and low and behold, my instructions are missing! i still have the video,, but i know the instuctions tell more. so is there any place to download them, or email them to bigguy6f4@hotmail.com
Also i got a recommendation on not even putting any of the washers that increase the shift performance in. the kit comes with 3. i do have teh corvette servo. should i not use any, or maybe 1?
i just threw my intructions out.. sorry man.. i didnt put a washer in, but now i kinda wish i had. if you have a stall, go with one washer. the instructions vary from the video. hopefully you can find them. or call transgo?
I got the Transgo shift kit with the corvette servos too. I didn't put no washers in and it shifts fine. If you have a stall converter you may want to addd a washer or two. With the radix, it spins the tires when it shifts from 1st to 2nd. As far as directions, not sure where they are. Good luck man.
If I had my scanner working I would scan them for you...
I originally put one washer in and ended up taking it out because it was too much. Even now with now washers, vette servo and tt3000 I bark the tires at anything over 1/2 throttle.
Bigguy, call me. Sent you an email. If you have access to a fax, I can fax them over to you. If you are going with a stall, do install 1 washer, if no stall, no washers. Any questions, ask hitman, flyer or myself.
James
James
jscherbs
09-30-2015 07:54 AM
2004r, cummins, directions, dodge, download, full, instruction, instructions, instuction, kit, manual, sheet, shift, transgo, video
