Help me build an exhaust for this 427 TVS truck
Would like to hear from you on the best way to design a true dual exhaust for this truck which is currenly choked by a catted 2.5 to 3" y-pipe.
I was thinking if I should go with 100cell 3" high-flow cats (vs current 200cell 2.5") and throw in a Dynomax dual 3" inlet dual 3" outlet internal x-pipe muffler, and two resonators before the tips.
dual 100cell high-flow cats, an x-pipe, dual Magnaflow straighthrough mufflers and small bullet mufflers at the back.
The first option would be the lighter one (better) and cheaper as well. The problem is im not sure how either one would sound
FormerVendor
Going catless compared to hi-flow cat will not change the hp output much, but the cats will help control the exhaust tone a bit.
Maybe run some cutouts. Stainless Works can custom make a muffler for you with a 3" inlet and dual 3" outlets, you can determine the length to help out with sound.
If I can help let me know, I can provide a special price for the forum customers.
Thanks for the reply. Do you think its possible to build me a complete true dual exhaust for my 1500 Silverado regular cab? If you could ull make my life much easier
Im thinking a true dual 3" exhaust would be the best, not a single three inch is killing it to say the least.
FormerVendor
ARC
57
02-21-2022 10:54 AM
lxcoupe
14
07-09-2015 09:15 PM
