Help me choose a cam for a 4x4
#21
Originally Posted by GregM
12 sec.5.3
Tell me more about your setup and how it acts thru the powerband.
GregM
GregM
#22
The application really has to be known before making a recommendation. If this guy with his 4x4 has a habit of attempting to go through mud bogs at top speed, then a new cam with a 2600-3000 stall is great. However, if he goes 4-wheeling in a traditional manner, which could entail 1 mph crawls through trails, and over rocks and boulders, he'll be royally screwed with anything over a stock converter. A slip of the wheels, and he could end up stuck, or inverted.
So I don't think your statement holds true - that a stall is good in 'all vehicles.'
#23
I've been considering a cam for my truck and have been playing around on an old desktop dyno program with some cam profiles. I'll say that a properly choosen cam will increase power thru the entire usable powerband.
Of the cams I tested, the Comp XR259HR(206/212) showed the most TQ at 2000. Other cams with 208/216 and 210/218 showed slightly lower TQ at 2000 but seem to quickly make up for it in the mid-range and at higher RPM's, while still matching or bettering the stock TQ at 2000 rpm's.
Now this was a make beleive motor on a computer program, so I can't say how well they will work in real life.
#24
That sounds pretty accurate, Silver...
There was a pretty in-depth "low duration, tight LSA" thread in the LS1 internal section... There were a few of us out there looking for torque cams. What you stated above, sounds a lot like what another member also found...
#26
Originally Posted by SportSide 5.3
COUGH:listen to big tex.
I do believe that the guy who started this thread saying that he wanted to PICK UP low-end torque. This tells me that the 208 cam is not for him.
#28
Point is, a tight lsa, short duration, fast ramped camshaft with as little overlap as possible is going to be a great choice for his needs.
#30
REALLY? please tell me how you know this
