Help me get my exhaust to stop leaking
Ive got LPP headers and their ORY, had the y-pipe welded together so it wouldnt leak and on the collectors i used butt joint style clamps that dont have the little step and theyre completely sealed. it works almost like cutting the slits in the pipe, just clamps down more on the bigger side because theres no step in the clamp. http://www.jegs.com/i/JEGS/555/30853...ductId=1256861
I'm not messing with expensive clamps anymore. I'm getting flanges welded on the collectors and the center part of the Y welded up. LPP should have put flanges on to begin with.
BTW I used those wide butt joint clamps too but they never seal up completely no matter what I did. I believe you guys about the slots but it won't be much harder to go ahead and get the flanges put on and I think its the best thing to do.
I just installed V-bands, and it is far better. LPP can't do this though as they would need at least one slip joint directly behind the tranny or it would be almost impossible for both headers to line up. If you do this yourself, just clamp the clamps together and weld it together with small welds so it doesn't warp. Slowly work your way around the pipe.
All right. It doesn't cost me anything to try the foil trick. I'll do that this afternoon and report back. If that doesn't do it then I'm drawing flanges with AutoCad, getting them cut out on the Laser and getting them welded on. I will defeat the exhaust leaks.
