Help me identify my metal shavings!!
#51
Quote:
Originally Posted by thunder550
Question....if I pull the bearing caps and the bearing is good, do I still need to replace it? Or can I just put the cap back on it?
A bearing that looks good with the caps off is 90% of the battle. To be sure of the bearings put a strip of plastiguage across the journal and torque the brg. caps down. Remove the brg. caps, measure your plasticguage and read your clearances. Check clearances to specifications to make the final determination. Again, if a bearing looks good then it is not a likely candidate to be shelling out copious amounts of shiny metal.
#52
Destroyer of Transmissions
Is this the first time you've had the pan off since install? Maybe the previous owner did some work on the engine (on an engine stand) prior to you getting it and never ran it. Whatever that is could have been lying in a crevis and once the oil started flowing got into the pan and maybe clogged the pump some. (Thinking Positive for you )
I'd pull the oil pump, inspect. Pull the cam, inspect it and bearings. If that all checks out...I think I'd put it back together. Before you pull the cam maybe loosen the rockers a little and rotate the cam and listen for any abnormal sound. Maybe a lifter is having issues and tearing up your guide trays.
Good Luck
Good Luck
#53
I pulled the pan before I put the motor in so I could put the ARP rod bolts on it, didn't see any shavings then. Only put about 10K miles on it since then. Supposedly the engine was from a wrecked Escalade, it was 100% stock when I got it. The only place I can see shavings getting in was the oil cooler lines. It would have had to get into the correct one that didn't go through the filter, I suppose it could have drained straight into the pan. I dunno. I'm so worked up about the 408 now that I'm going to pull the LQ9 anyway. I'll inspect it, and if everything checks out I'll probably put it back together and end up selling it complete, or as a short block. I still have the stock oil pump off my 5.3, so I can replace the one on the LQ9 just in case something made it's way up in there. I think inspecting the rod and main bearings and pulling the cam will tell me the story....if I don't see anything, I can't imagine that there would be a problem.
#54
Well I tore into the motor today, all of the bearings looked great, put everything back together, swapped oil pumps from my old 5.3 to see if that would fix the oil pressure problem, sealed everything up, everything looking good, and then......threads inside the crank snout strip out while I am putting the balancer back on
So the motor has to come apart anyway now. Might as well part it out since there's no chance I can sell it complete.
#56
lemme know when you're going to start parting out the motor, im interested
