help me with my ATI S/C i cant get the power i should be
Old 05-29-2005, 05:03 PM
  #61
lm7
lm7's Avatar
email is in my sig send some if u can.
Old 05-29-2005, 05:40 PM
  #62
pics sent
Old 05-30-2005, 06:42 PM
  #63
lm7
lm7's Avatar
got em damn everything looks good i mean ur using a diffrent BPV than i did but it seems to be set up poperly. mine was before the IC right after the blower. this is really starting to **** me off. any chance youll be in northern cali soon? i know how frustrating it can be i know theres times when i get like **** isnt the answer written somewhere someone has had to have had this happen to them besides me.
Old 05-30-2005, 09:12 PM
  #64
14 Second Truck Club
If you have a tune-up vacuum gauge, t it off of your line for your in truck gauge and compare the vacuum readings. My blower didnt really feel like a huge difference this time around either, but SOTP doesnt tell the whole story.
Old 05-30-2005, 10:04 PM
  #65
i don't plan to make a trip to cal.
I should be getting two smaller pulleys tomorrow, i will try that, and see if that helps. i might also get a Dakota Digital vac/boost gauge to try and see if there is any change
Old 05-30-2005, 10:27 PM
  #66
What size pullies are you going to have, and what size are you running?
Old 05-30-2005, 10:38 PM
  #67
right now i have a 4" on the truck and i will be getting 3.65 pulley to get 10lbs of boost and a 3.80 to get 8
Old 06-01-2005, 11:05 AM
  #68
When we lowered the timing way down to around 2 we could get the 6 deg. of knock to go away. But I think we should be able to run around 12 deg of timing.
Old 06-01-2005, 02:39 PM
  #69
lm7
lm7's Avatar
that much knock u must be running lean. how is FP? is inline pump turning on? does your FP spike lean when u go WOT? pull a spark plug if shes white u have a problem.
Old 06-01-2005, 03:09 PM
  #70
once i got my gauge working the FP looks good. i will see what it says again on the way home from work, and then i will post up.
Quick Reply: help me with my ATI S/C i cant get the power i should be
