Help me pick a cam for my lq4 lol
I know this gets asked every other minute, but then again not all of our setups are the same. Especially since this is in my 2500hd.
Its a rclb 2500hd 2x4. 5300lbs with me in it. So far I have added the following mods: ls6 cam and heads, UD pulley, pacesetter lt's, nelson tune, 31# truck injectors, 245mm 3500rpm stall, transgo hd2 shift kit.
Last time at the track it ran 13.81 @ 100mph w/ a 2.01 60'. This was before the ls6 heads and hd2. And this was on the stock wheels and tires.
So im looking for a cam that will help turn the best et's. The cam will be my last mod. Im hoping that between a bigger cam and the ls6 heads that I will be able to run mid to low 13's.
This is also my DD so im not looking for anything too crazy. I dont mind if it lopes a bit, but its still my work truck so i dont want it to sound like a racecar at idle. I was thinking of a tr224 on a 112, what do you guys think?
I ended up going with the TR230/224, hopefully its not too crazy. They said that it has pretty much the same powerband as the TR224 but it just makes a bit more power and better torque.
Thanks for the help ill let you guys know how it turns out
GrooveCityZ71
08-31-2015 12:05 PM
lxcoupe
07-30-2015 02:42 PM
