Help My 05 Fans Dont Work!!
IDIOT OF THE WEEK AWARD>>>
well I am the problem with the fan install, big surprise, I looked at everything again and started with the voltmeter at the +/- hookups, big surprise I had installed the harness onto the wrong terminal at the fuse block.. there are 2 studs with red leading coming out from there and only 1 has constant 12v, the one I hooked it up to did not... DUH!!!
Anyhow that seems to be the prob, although as someone described above, I don't have the AC trigger, I went back to Bryan at PCM4less.com and he verified that my program has the fan turn on but stated that this does not include any AC trigger that it uses a seperate wire for this, which he could look up for me and I could then jumper that to the manual switch wire they have in their harness which I am currently not using... Anyone have a different hook up???
mr03silverado
07-17-2015 02:15 PM
