Help! Overheating....
PT's Slowest Truck
My fans work just like you described...they only come on high with the ac on, and one comes on high with the ac on and the low fans off (hasn't reached fan on temp). You could wire a second toggle switch in to the high fan wire to have manual high fan operation (I'm thinking of doing this myself). Just be sure to put a diode in the circuit to avoid activating the a/c compressor when you hit the switch since it's a 12v source instead of ground.
High on diesel fumes
Originally Posted by Hemi Killer
When I turn the toggle on, both fans come on low. When I turn the a/c on, the passenger side fan comes on high while the other is still on low. If I don't turn the toggle on and turn the a/c on just the passenger side fan comes on high and the other doesn't turn at all.
formerly 1BADC10 (12/14/2011)
Originally Posted by Soon2bSpooled
if you put seofoam in your crankcase its going to make your oil even thinner. FYI, most people put the seafoam in then drive around a little but then change the oil, 100 miles should be alright i suppose
Originally Posted by 1BADC10
Wanna run about a 100 more, drain, then fill with conventional + STP oil treatment.
I hope to be "Ridin' Dirty" before November!
you are overheating because of your electirc set up, what should be happening, a/c on and toggle on both HIGH it would be pointless to have 2, 2speed fans when you couldnt get the maximum potential out of both of them at the same time.... i have one of whit1's harnesses with a toggle....
toggle off, a/c off- both off
toggle on, a.c off-both low
toggle off, a/c on-one high
toggle on, a/c on-both high
14 Second Truck Club
I appreciate all of the responses! What should I do? Try to drive down to Futral tomorrow and see if I can get it hooked up to the pcm (4-5 hour drive) or is something wrong with the harness?
Swap your relays around and see if the behavior of the fans change. If so, go to Napa and get yourself another good relay (stay away from the cheapo ones that Checker and AutoZone sell) and replace the bad one. Make sure you look for a 40amp relay. If you have a bad one, you'll be able to tell because it will look like some of the plastic right around where the contact goes into the relay is melted.
PT's Slowest Truck
I forgot to mention that I got the other fan fixed. Both fans work. I also got the nelson fan harness that is hooked up to a toogle switch instead of the pcm.
If I was to overnite my pcm to futral and pay to have the pcm turned on and hook up the wire to the pcm, would this turn both fans on high when it gets hot with the nelson fan harness? Would this solve my problem? What about a bigger radiator? Could I still run the same fans? This is driving me crazy!
