Help! Plug wire removal.
Okay this probably sounds stupid. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> But how in the heck do I get the dang plug wires off so I can remove the plugs? I assumed that they would just pull off but this does not seem to be the case. The little heat shroud thing I think is holding them up somehow? Any help would be appreciated.
Thanks,
Kevin
Thanks,
Kevin
Re: Help! Plug wire removal.
No problem dude. When I pulled mine off and the whole thing came off I was like WTF I broke it, but I figured out that they are supposed to be like that. Let me know how the back passenger side (#5?) plug goes. Mine was a pain in the @$$ took like 20-30 minutes.
It wasn't too bad. Other than the fact that my truck now has skin on miscellaneous parts in the engine compartment, everything went okay. I put the ratchet on it with a swivel on it and was able to put a tad of an angle on the wrench with a two inch extension it came out fine. I had it out and back in within 5 min. Once I knew what to pull on to get the plugs out everything went okay. I am a bad mechanic <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks again for the help. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Tydriver
45
10-23-2015 09:19 PM
SlvrSierra4.8
10-01-2015 09:39 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
