Help a PT.Net Guy out...Retarded 6.0L Question
Praise The Lowered
^The PRC "5.3heads are indeed 5.3/4.8 castings ..not 243 which are ls6/ls2
any year Lq9 (Vortec max,Silv SS,Escalade)
-Prc Stage 2.5 ls6 Heads
-Tr224 cam
-ls7 lifters
-arp rod bolts
-current bolt-ons
the compression would also be raised with this combo,as 317 heads have a 72cc chamber to the 243's mid 60's 64.xx??
-Tr224 cam
-ls7 lifters
-arp rod bolts
-current bolt-ons
Praise The Lowered
Its hard to say for sure but the motor itself should make north of 450 hp...The main thing is you would build it with proven off the shelf parts..If you are concerned with making big numbers and want to spend some dough than get some Trickflows and a big Patg spec'd cam with a LSXrt intake...
-The ls7 lifters are capable of higher spring loads and rpm's..for the price they are hard to beat...and dumb not to replace
Praise The Lowered
If you can find one used..I was debating it, but my truck runs real good with the truck intake/ported 78mm tbody..put it this way ..If I dropped the coin on a set of TF's...I would buy a Fast intake/92mm tbody..wouldnt feel like I was getting the most out of the combo..if I diddn't...but they sure do look good..lol
