Help with shift points
I'm looking for some advice on where to have my tuner set my shift points. My mods are in my sig... I've ran my best times manually shifting the truck at about 6000rpm, which is probably 100rpm shy of the rev limiter. The engine has about 100k miles(maybe a lot more, lol) and stock rod bolts, so I understand keeping the rpm down a little low. Right now the 1-2 shift is ~5800 rpm and the 2-3 is ~5600rpm.
Here's some dyno threads with similar engine setups:
https://www.performancetrucks.net/fo...d.php?t=446380
https://www.performancetrucks.net/fo...d.php?t=456408
What you guys think?
mines set at 6200 on regular and 6300 on tow and haul... i might bumb it up a bit since i was told i can get power till 6400-6500 on this cam.. it might be small but its got potential..lol
jtphelps289
09-29-2015 12:00 PM
TAPyvehc93
09-14-2015 01:22 PM
