Help truck not cranking!
Old 10-25-2007, 05:14 PM
14 Second Truck Club
Default Help truck not cranking!
I just did the 90mm F.A.S.T. Intake swap. Everything is connected, checked like 5 times including the grounds.
Let the fuel pressure build up about 7-8 times before cranking it. Cranked it, it idled below 500rpms surging and died. Hasn't cranked since. At first I thought it was the VATS. Did the system relearn = nothing. The security light didn't even come on when doing it. Thought it was the battery, tried jumping it = nothing. I pulled most of the plugs out and most of them had a bunch of carbon on them, replacing them right now.
Any idea of what this could be?
Old 10-25-2007, 06:10 PM
Mr. Obvious
nightrunner's Avatar
maf clean?
blown fuses?
Old 10-25-2007, 06:26 PM
regency's Avatar
do you have a retune for that big of a intake and throttlebody
Old 10-25-2007, 06:47 PM
dirt track racer 81's Avatar
map plugged in?
Old 10-25-2007, 07:53 PM
I got my tune adjusted through the mail from futral. The MAP sensor is plugged in, but the fast intake doesn't have any clips, but it's in there. What fuses should I check and where?
I took my alternator to the auto store. The charged my battery as well. It was low, but not too low. Fixing to go install the alt. & battery and see if the charge made a difference.
Old 10-25-2007, 08:37 PM
Mr. Obvious
i was just shooting in the dark, maybe a pcm fuse or something important was blown, id check them all.
Old 10-26-2007, 05:37 AM
11 Second Truck Club
bluecajun5.3's Avatar
look at the fuses in the fuse block under the hood to see if it's blown. it's one of those big ones. this sounds the problem.
Old 10-26-2007, 12:17 PM
It's Running!!!!!!!!!!! I swapped the starter & ingnition relays to see if one was bad and cranked right up. Thanks guys!
wrb002
08-31-2015 12:00 PM
chevyl33
08-24-2015 08:21 AM
InsaneDomestics
07-27-2015 02:42 PM
black6spdz
07-16-2015 01:32 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: Help truck not cranking!
