HELP! WHat would YOU do?!?
#33
Yes I coils for everything, caddy motor, camaro motor, and the original 5.3l truck coils and accessories. Basically my garage is full of a ton of stuff for these motors its just a matter of setting up and going.
#34
I have another question, probably dumb but oh well. What computer do I need to use for each vehicle? I have a total of 3 computers, the stock camaro LS1, the caddy 6.0L, and the truck stock 5.3L computer. Since I am putting the 6.0 in the camaro and the camaro 5.7 in the truck, which vehicle uses what computer? Thanks again
#40
Laid Back
Plenty of guys go .050"+, so i'm sure .040" would be fine. Just don't forget to check pushrod length or take the easy way out and order some 7.360" rods.
With the headbolt issue, you're talking about the LS1 having the long headbolts and the 6.0 having the short ones, right?
You need to match the headbolts to the blocks. The heads are the same. You can pick up some head studs off ebay or just order some replacments from rockauto/parts store.
