Help Wiring Up MDS Injector Plugs
Old 08-20-2007, 04:34 PM
1TRUESS's Avatar
Default Help Wiring Up MDS Injector Plugs
How did you guys wire these in? Does the common pink wire go into A or B side or does it even matter as long as they are all the same?
http://store.summitracing.com/partde...0&autoview=sku
Old 08-20-2007, 08:33 PM
1TRUESS's Avatar
No one has used these?
Old 08-20-2007, 09:59 PM
closet red neck's Avatar
Just put the common color(pink) to that side. The injector plug only goes one oneway. The driver's side is one color and the passenger side is another.
James
Old 08-20-2007, 10:27 PM
11 Second Truck Club
bluecajun5.3's Avatar
all i can say is have fun
Old 08-20-2007, 10:44 PM
Yeah, no ****!!!!!LOL!!!!!!
James
Old 08-21-2007, 12:13 AM
5 year bitches!
Quik's Avatar
the common pink wire is the power wire from the fuse box, the other wire is the signal wire from the PCM. i foudn this out when i made a standalone harness
Old 08-21-2007, 01:09 PM
1TRUESS's Avatar
What side?
Okay but does it matter on the injector plus or minus? I have no reference to look at. I am going with LS1 style and getting rid of my truck injectors that I no longer have.
Old 08-21-2007, 03:15 PM
03sierraslt's Avatar
ya I need to know this as well..
Old 08-22-2007, 06:10 PM
1TRUESS's Avatar
Anyone? How about if the injector connectors are facing the out side of the rails the passenger side pink wires are near the front and drivers side the rear?
Old 08-22-2007, 07:21 PM
1TRUESS's Avatar
Here is a quote from LS1Tech
Originally Posted by LS1MCSS
On an 01 LS1, the pink wire goes to the A side of the plug on every injector. Hope that helps you.
Anyone else want to confirm this?
Quick Reply: Help Wiring Up MDS Injector Plugs
